1G and 7M similarities?
Kai
That Limey Bastard
Are there any similarities between the two engines? I know theres a capacity difference (2.0 and 3.0 respectively), but for the overall design of them, can anything be swapped over?
Mainly curious to see if its possible to use the 1G-GTE's Twin Turbo setup on a 7M...
Ma70.Ent
1,871
NJ
Check out the other engine tech section, in the 1GGTE info topic. Some of the posts may give you clues. If anything, just PM one of the guys and see if they can tell you. supra_grrl and projectsupra come to mind.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
the 1g and 7m are very different the only things that are the same are like coil, pulleys, belts ,alt. etc not very much.
