1992 Toyota Supra Starting Issues
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
i just bought this supra and i tried removing the factory alarm.
i removed the anti theft black box.
grounded the blue and orange wire going to the connector thats connected to the black box
i also did the 30 amp relay mod
(connected power from bat to relay. neg to ground. ignition to relay. relay to starter)
the car cranks and cranks perfect . then starts after about a minute of attempted starts
and after it starts i must rev to about 2000rmp to warm it up. if not it stalls
after warm it drives perfetly
i drove it today after this process
when i got home
i tried starting it again and now it just cranks with no start.
has anyone has this problem too?
im going to post a video how the continuous cranking then starting
thanks
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
zachm611;1218977 said:
is it getting spark while cranking?
i didnt check all of them but as soon as i saw the bottom sparkplug wire sparking i was quick to assume that they all are getting good spark
so the answer is yes
8,900
Why did you remove the noise maker? Just wondering.
Your car had a starter relay already.
then starts after about a minute of attempted starts....and after it starts i must rev to about 2000rmp to warm it up. if not it stalls
So pull codes. You can also ground the cold start injector time switch and see if it starts faster. And unplug the ECT sensor and see if it starts and runs better. Check both of those seperate and together.
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
i did the. 30 amp relay mod and i can finally start my car with the key. and no i didnt remove the nose marker cuz i couldnt find it. at all.
im going to check out the grounding of the csi. and where is the ect sensor.
thank you
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I think you probably have two issues. Has the car always done this or just since you did your mods?
At the beginning of your vid, it almost sounded like the notorious CPS wire problem. I'd give it the 'CPS Wire Shake' and see if that helps.
BTW: Fan Shrouds are your friend! :)
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
its always done this but before i use to start the car with a wire
and with the mod i can start it with the key now
i am not too familier with the cps wire
im a noob
can you help me out?
CajunKenny
Nov 15, 2007
3,255
Washington
There are wires that run across the valve covers right behind the Cam Gear Plate. It's toward the front of the engine. Basically, wiggle any wire that you see. Don't jerk on them like you're trying to start a lawn mower though! :D
The CPS is on the passenger side of the engine toward the front. It is mounted on the side of the head kind of behind the thermostat housing. It has a black plastic top on it.
Hope that helps.
This sounds like a scary setup by the way... I'm glad it's in your hands now so you can do things right and treat a Supra the way it ought to be treated! :)
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
Hope that helps.
thanks im going to record me trying all these things
thanks for you help
and trust me
i will take care of this baby :love:
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
i got code 12
RPM Signal
Diagnosis
No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked.
Trouble Area
Distributor, or CPS, circuit
Distributor or CPS
Starter signal circuit
ECU
and i got code 22
22 Water Temp Sensor Signal
Diagnosis
Open or short circuit in water temp sensor signal (THW).
Trouble Area
Water temp sensor circuit
Water temp sensor
ECU
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
UpbeatFish;1219771 said:
i got code 12
RPM Signal
Diagnosis
Trouble Area
Distributor or CPS
ECU
and i got code 22
Diagnosis
Trouble Area
Water temp sensor
ECU
i just checked again after fixing some wires that were loose
and i have no codes anymore
help anyone?
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
i think i found the problem
when ever i crank the car there is no spark. there was spark before but now there isnt any
someone said to ground the coil packs
and i was looking where can i find the origal grounded wire but i cant spot it
only the female and male connected to the coil pack
where is the grounded wire
CajunKenny
Nov 15, 2007
3,255
Washington
The coil pack ground wire is on the passenger side, front of the coil pack bracket and goes almost directly down and bolts to the head. If you have a volt meter, check the continuity of the wire.
Something else I noticed (you may have already fixed this) is that when you turn on your key, your RPM needle doesn't stay at zero. Does it still do this?
8,900
You won't have spark without a pick up signal. Or fuel.
That is fine, but adding a relay didn't help start the car. I was just curious. Good to hear it cranks over now.
I don't know what you are talking about, so don't worry about it.
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
me and my friend clean some wires and put new ones and i notice there isnt any spark comming form the ignition coil?
is there any troubleshooting ideas to get it working..again
when i crank the rpms dont move....
HELP!!:1zhelp:
8,900
HELP!!:1zhelp:
i got code 12
RPM Signal
You won't have spark or injection without a signal indicating engine position and speed.
Check again and see if the code came back.
