1990 JZA70 Rad Leak
got_rice_?
12
Swift Current
As it says, right under my filler cap i have a hair line crack about an inch long, i have tryed apoixes to fix it and what not and they hold untill i hammer on it then it just blows it out, i have been looking for a stock rad or aftermarket one everywhere but cant seem to find one, i found one on ebay by Godspeed?
http://cgi.ebay.ca/GODSPEED-86-92-S...ryZ33602QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
but its says JZA70 7MGTE? which doesent make sence to me, would they fit does anyone know? also my car started to drip anti freeze the other day, havent had a chance to put it up on a hoise yet to find out but its near the water pump but the car does not over heat or anything, runs at normal temp even after i drove for 3 hours. and the other night after 2 hours of driving i got home and there was no leak at all so maybe a loose hose clamp on the thermostat or something or water pump gasket? thanks for the help guys.
Not quite...
The mounts for the fan shroud are different, this is why using the Koyo with the 7M requires customs lower brackets.
For a JZA70 it will be a true drop in radiator, and be an nice upgrade.
GO KOYO!
makaveli913
1jz and lovin it
Nov 20, 2007
135
Pueblo Co
its a 90 jza70 rad. im doin the swap right now. the 1j is in and everything is geting hooked up. By friday i can let you know if its going to be used. ill let you know on a reasonable price.
got_rice_?
12
Swift Current
so its 12:00 am here so that means its friday, so how much for the rad if your not using it haha.
