1990 7MGE clicking when accelerator pedal depressed.
suprunner
south dakota
Hey all,
I've been driving my (1990) 7MGE '86 4Runner around North America. The power gain from the 22RE is efficient. I've ran into a few problems that I'd like to know if they're related or not. .
The wires fell off of the connector for my Cold Start Injector. Now, when I first start the motor in the morning, it takes a few tries. I know that that will be a simple fix. I think. Are the connectors easy to rewire? If not, does anybody have a connector with any length of exposed wires?
Connector, BEFORE wires came off:
BUT, my main question has to deal with my Idle Air Control Valve (IACV). It has started clicking. . . whenever I depress the accelerator, it makes about three or four rapid clicks. If I'm driving at a constant speed, then accelerate again, it'll do the same thing. Is this tied to the cold start injector? Is it bad? When I did the swap, the original IACV was no longer useable. Very corroded. I replaced it (used, but cleaned it and installed new bearing) and moved on. . .
Any help will be much appreciated.
Thanks,
Greg
