1989 turbo
Andymk3
Hello recently did A rebuild on 7mgte had a rod knock but was running fine. After the rebuild car is idling rough have a code 52 for knock sensor Seems to be running in limp mode but if I get on the throttle easily sometimes will get it to rev up definitely sounds like it has a misfire seeking some help on fixing this issue any help would be appreciated thank you
