1989 turbo mk3 smokes ...
Merkhunter
merkhunter
Jan 31, 2008
24
so cal in the sgv
i have a 1989 toyota supra fresh rebuild. and it smokes as soon as i get out of boost and i can smell oil burning off. what could it be.... bad VALVE SEALS .....
turbo seals.... or piston rings.... could someone help me out on this one. oh and its A DRIFTMOTION CT 26 57TRIM . WITH ONLY 4 000 MILES ON IT.
Hmong_1G
Name the Place and time.
Dec 31, 2008
280
California
Take the turbo off and inspect for bad seals. Easily noticeable. What brand valve seals did you installed and did you also installed new valve guides? An easy way of inspecting seals or guides is to take out the spark plugs and inspect the piston tops. You would want to do this with the vehicle sitting over night. If the tops are wet, then seals or guides.
Merkhunter
merkhunter
Jan 31, 2008
24
so cal in the sgv
ForcedTorque;1344644 said:
Have you contacted Aaron? Call him, and tell him you suspect turbo seals, and follow the directions he gives you. Continuing to run it may void anything he could do for you.
k ya i havent yet but i could do that, what do you think it is personally , i think its the turbo seals....
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
burning oil off boost and decel is usually valve seals, but was it smoking before your put the motor on or was it on all at once?
Merkhunter
merkhunter
Jan 31, 2008
24
so cal in the sgv
it doesn't burn oil during decel. just after i get into boost and switch gears then you see a huge puff of smoke come out the back. so im not sure . and it burns a little sometimes at idle but only after ive been running for a min,. then it stops after it cools down a bit. any ideas???
