1989 MkIII Supra often refuse to crank over when hot
shipkiller
398
Quebec
I've been battling this issue recently with my mk3.
1jz 1989 with a R154.
It started to refuse to crank over randomly when the engine is warm/hot. At first it was rare but now it's almost everytime the engine is hot.
I redid the wiring harness last year, so i'm pretty confident the starter is triggered everytime I turn the key but the lights barely dims. I can hear the starter relay click.
I'm using the OEM starter power cable, battery has plenty of voltage (I even tried boosting it with another battery just to be sure).
It will crank over (and start) everytime when cold, no problems there.
Do I need to replace the starter motor? I want to be sure before pulling this thing.
thanks
shipkiller
398
Quebec
Replaced the starter, wasn't the starter.
I've mesure the trigger voltage when I put the key to crank position and I'm only getting 8-9V instead of the 12V+ (without the big cable connected so that the starter wont spin).
I might have to replace the trigger connector+wiring from the body harness connector to the starter.
shipkiller
398
Quebec
I did, I also upgraded the grounds last year when I made the wiring harness. I have one on the block, head and intake manifold plus one chassis to neg battery directly
8,900
You beat the odds by a large amount. Heat soak 101.
Heat soak. Heat increases resistance. On the old wires with corrosion on the inside that you don't see (assuming the posts are accurate) it is worse. It is dropping nearly 4 volts. Do the voltage drop test on both wires, especially the large one.
