1989 Automatic 7m-gte supra dies when put into drive or reverse.
xpaperroses
California
Hey there.
I just rebuilt my 7m-gte engine about a week ago, due to it overheating.
I finally put everthing back just as it once was when it was running.
There were a couple issues such as vacuum leaks and faulty wiring.
When the car is in park it runs for a while then turns off. It turns back on with no problem it just wont stay on for long.
Basically my question is when the car is finally running when i put it in drive or reverse it just dies. What could be the possiblities?
xpaperroses
California
BlackMKIII said:
Check the basics: Air, fuel, and spark. If all three are happening well enough, let us know.
Yes those things are happening well enough.
The car runs, just when I put the car in drive it dies.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
does it stall out from load? or shut off like you turned the key off? try revving it a little when putting it in drive, not much and make sure your not in front or behind anything in case the car jumps a little.
8,900
Can you neutral drop it and see if it moves? Don't keep doing this either, just once or twice to see what it does. You could have a converter lockup problem.
