1987 supra strut noise
ccwade
supraman
Dec 27, 2006
32
Central US
when i repeatedly push down on the front fender, i hear a slight popping noise. It sounds like it is coming from the strut assembly. I originally noticed this noise when i drove out of my drive way. The slight popping noise annoys me.
I took off the TEMS assy. and checked and tightened the nut on the center strut stud. Noise still there. please advise tks
bowsercake
828
Irvine, Ca
If the bolts on the top of the strut are tight, I would check the ball joint. Jack up the car and push up on the wheel, if it moves at all your balljoint should be replaced. Check the bushings under there as well, I had a bushing in the rear squeek, just put some wd40 on it.
ccwade
supraman
Dec 27, 2006
32
Central US
i will check the ball joints per your instruction tomorrow.
how do you inspect or check the bushings to determine if they need replaced?
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
How do your bump stops look. I installed kyb gr2's, ST springs and new bump stops. My bump stops in the front would pop on me until I trimmed about 1-2inches off of the plastic.
