there's a guy locally that is selling a 1987 honda CRX for 200 (and said make offer so he might take less)...
he said he's sick of putting thousands into it, and he told me that he wasnt able to register it because it wouldnt pass smog. he said the catalitic converter glows red hot and the engine starts running bad....(woah)
so i'm thinking its definitely a clogged cat. I was wondering how much this would be to fix and if it could have damaged the engine or anything from the heat....
if i could get this car, put on a new cat, smog, and register it for under 400 bux, i think i might have a nice deal. but i'd ONLY get it if there weren't chance of engine damage....or other problems associated with this. here's what he said:
"It has a new carb, radiator, all fluids, filters, good tires. When it run the catylitic converter heat red hot and the car runs rough. No fluid leaks of any kind. I thought about cutting the cat converter off and seeing if it will run better but I dont have the time. It also needs a rear brake job, temperature guage doesnt seem to be accurate and the fan doesnt kick on. The engine doesnt sound to bad. No knocking or anything. Hopefully this info was helpful. Make an offer."
