1987 7mge cams
Rowdysr
Placerville
my thing is i need new cams and ive got a set for free but they came out of a turbo just wondering if it would hurt anything or?
gofastgeorge
944
Texas
Won't hurt a thing.
Actual timing spec.s are so close, that you probably won't notice.
Just check your valve clearances, and shim to get into factory spec.s, and you will be fine.
5
Lienhop Photo;1496293 said:
im going ot be running turbo cams on a non turbo head.
Heads are all the same...
Also, the NA cams are tuned for the ACIS system, probably going to hurt power...
