1986.5 Supra Restoration Story
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
74
Atlanta
Well,
Good luck with the engine refresh. While the engine is out, it'll give you an opportunity to look over the chassis wiring, since all of your aforementioned electrical issues are seperate from the engine harness. It sounds like a power short, and maybe the fusebox is the first place to inspect.
zhenya
24
12
The engine is officially out of the car and dropped off with the builder! This is by far the biggest step in the project I've taken since buying the car 6 years ago. And it's the first time I've completely pulled an engine out of a car, so lots of new experiences.
The clutch is not in the best of conditions. I have no idea how this happened, but definitely explains why it was failing that badly.
Also, a lot of the hard line coolant passages looked rough. If anyone has any advice on how to modernize a lot of this stuff to get rid of the million vacuum hoses and coolant going everywhere, I would greatly appreciate it. I don't want to put anything that's had rust going through it back on the fresh engine.
And finally, I'm still not any closer to deciding what to do about my wiring.
zhenya
24
12
Small update time. I have been taking the supra apart slowly, and the engine is back from the machine shop. Got distracted a bit because my other car's engine let go, but we'll get there. First I want to get the car completely taken apart, and fix the rust.
zhenya
24
12
A sad update today. Got pretty much everything except suspension off the body of the car and found some really bad rust.
I don't have the skills to fix something like that, so I honestly have no idea what to do.
zhenya
24
12
Welp, this is the end of this story. I wish I could fix this car, but honestly considering the damage, it's not possible. So I'm making the responsible choice of ending this project here. Thank you everyone for reading along.
MoparMarq
19
Vancouver, WA
Sad to see a MkIII end life that way, but understandable considering the rustification. Looks like you got a ton of parts off it though, so you can offset your expenses some.
