14mm fuel rail and I have 7mgte 550cc injectors..
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Story is, I bought an FFIM for my 2jzge na-t that comes with its own fuel rail that is for 14mm injectors... I looked around and found out my 550cc injectors I pulled from my 7mgte to my 2jzge na-t are 11mm. Any way to get other orings or do i have to buy domestic style 14mm injectors too..?
RacerXJ220
Interdimensional
Abalama
nosechunks;1468503 said:
7m injectors are different from jz injectors, You need jz injectors if the rail is made for jz injectors.
7M injectors fit in the stock 2J-GE rail.
I ran into that problem when I went top feed on my 1J and I wanted to keep the injectors I used on my 7M. A lot of aftermarket rails are made for 14mm injectors but I found one that worked.
You'll need the other injectors with that rail.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Yea I pretty much figured I was going to have to buy new injectors.. Was just hoping I could get around it somehow. ahah.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,776
Long Island, Ny
So the turbo rail is different? Learn something new every day!
