12v relay mod vs 12v constant mod pros/cons
Turbo Habanero
4,229
Tucson,AZ
So I'm about to put a walbro in the car tomorrow and was wondering witch is a better mod for the fuel system.
One other question. Can I bypass the stock relay and resistor safely? And just take that stuff out of the engine bay.
Thanks Jordan
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
I think you're confused. The 12V mod is to switch the pump over to a constant 12V source. Its not NEEDED but i highly recommend it for tuning purposes and, potentially, safety purposes.
Yes you can remove the resistor pack and relay when the 12V mod is done properly.
Turbo Habanero
4,229
Tucson,AZ
Yes i was. There are two different mods but apparently they do the same thing lol. One uses factory wiring and the other is the link above. :) thanks for pointing that out
Turbo Habanero
4,229
Tucson,AZ
So i can just just jump the stock relay and resistor and then remove them ? seems awful easy lol but i'm understanding this correctly ?
