12k tear down update
quake
toyota tech
Apr 13, 2005
619
r.i.
so we have an update now here are the pics.
quake
toyota tech
Apr 13, 2005
619
r.i.
Fresh paint and primer
quake
toyota tech
Apr 13, 2005
619
r.i.
new rods and bearings clevite, also changed the specs. Will be going with 10w-60 oil all arp main studs and head studs also line bore done all rods resized upgraded piston pins and forged pistons
quake
toyota tech
Apr 13, 2005
619
r.i.
swapped out my hks manifold and also in process of making a new intake plenum head has been bead blasted
quake
toyota tech
Apr 13, 2005
619
r.i.
upgraded valve springs 3 angle valve job 9:1 compression
quake
toyota tech
Apr 13, 2005
619
r.i.
bigger pics me and my helper:sarcasm:
quake
toyota tech
Apr 13, 2005
619
r.i.
more and it's in
quake
toyota tech
Apr 13, 2005
619
r.i.
got much more to do but i got 1hr a day now when working also need to remove much from the bay and get a throttle cable i hear there's a vid comming out too lol
Could also brighten up some of the pics ;)
quake
toyota tech
Apr 13, 2005
619
r.i.
Doward;879798 said:
What the hell crazy clearances are you planning on running, to put 10w60 to use?
i was a .0015 mains and .001 rods but after speaking with IJ and inspecting the bearings after the tear down i went up to .002 rods and .0025 mains so i will be 30w break in 50w daily and 60w road race all was set up for these numbers so i will be fine
quake
toyota tech
Apr 13, 2005
619
r.i.
will post up new numbers and vids soon after break in also will switch to stand alone after break in
