10 blade radiator fan
allen600
166
oakdale
I am wondering if anyone can tell me the diameter of the fan blade, I'm trying to check clearances to my intercooler pipe without buying one, I am 2jz swapped and am trying to switch back to mechanical fan from electric! Also is the 10 blade fan from only 7mgte? All years? How about the radiator shroud, are the 7mge and 7mgte all the same? All years?
Thanks for you help ladies and gentlemen!!
loc182
279
11
Grove City, Ohio
I can measure my fan when I get home tonight as it is out of the car, but I suspect someone will have this info before then!
As far as the fan used on the 7M-GTE, based on the EPC it is the same part number for all years of the MKIII with that engine. The 7M-GE uses a different part number, which appears to be a 7 blade fan.
This is the 7M-GTE part number for the fan: 16361-42020
The fan shroud has the same part number for both the 7M-GE and 7M-GTE engines on all years of the MKIII. (16711-42060 for the main shroud, 16702-42010 for the lower piece)
All this info comes from the EPC and I checked the part numbers at Champion Toyota. But if anyone has more info please correct any errors!
loc182
279
11
Grove City, Ohio
Sorry for the delay. Measured this morning and it was 17.5 inches in diameter. (My car is a 89 Turbo.)
Had I been more awake I would have measured the fan shroud too :p Let me know if you need that.
