Hey wassup guys, as some of you know I now have a 1jz. Thats not the reason for the thread though, Im curious about doing the 1.5jz and using a 2jzge block. I would like help deciding either to get TT pistons and rods and use the oem headgasket, using the stock pistons and rods with a thicker headgasket or just using the stock pistons and rods with the OEM headgasket. I am aware all of these will yeild different compression ratios. Which would be better though? (or to you) making more power down low without being able to run massive tons of boost. Or not make as much power bottom end but having the advantage of running more boost? Im asking all of my questions before I start buying parts out wazoo because i want to be efficient with this setup that I can rely on. Also since I have a standalone would I need to retune? I've asked several people all with different answers.
Thanks
Thanks
