‘88 Supra Turbo No Start (Cranks/Fuel/Spark)
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
Good morning Team - just working on a customers ‘88 Supra Turbo Auto - he recently purchased this as non-running and was told it was a fuel pump. I had him bring it over to me and I confirm that there’s fuel pressure at the rail. He said he was able to get the car started one time for a minute and a half with starter fluid but didn’t use the starter fluid the whole time so I feel potentially fuel is fine.
Items I’ve already confirmed:
-Checked timing belt is in good condition and timed correctly
-NO CEL
-check spark, engine has spark
-checked fuses
-I have another car that I’m parting out so I was able to swap some parts just for a quick verification. ECU is fine, coils are good, and igniter.
Thanks for any recommendation
Bru
111
57
28
Tampa Bay Area
The fuel pump can be activated with out starting the car by jumping Fp and B+ in the diagnostic block behind the battery with the ignition switch in the on position not cranking. You should hear the whoosh of fuel at the pressure regulator in the rail. I don't know where he sprayed the starter fluid, but you can kill the Karman vortex air flow meter with liquids. Here's a link to the 1990 online manual that could be useful. Check that the fuel is not stale / discolored.
te72
Classifieds Moderator
6,626
10
WHYoming
Have pressure at the rail, and it runs on starting fluid? I'm not a professional by any means, but I would suspect there is an issue with either the age of the fuel, as Bru mentioned, or perhaps the injectors themselves. Can you confirm that the injectors are operating as they should? Easy enough to drain the fuel tank, it has a 3/8" square plug in the bottom of it. Plug it back up, throw a gallon of fresh 91 in, and see if it improves. If not... I'd be looking at injectors.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
I'd be checking the CPS and the TPS, both have a tendency to go, moreso the TPS and both can definitely cause problems -- but you also said no CEL so...water in the tank? Ancient fuel filter? How long was the car sitting vs last time it was routinely run?
