Why I Picked Quick Extender Pro for Penis Enlargement. My Review
powerdude
Why I Picked Quick Extender Pro Over Phallosan Forte and Penimaster PRO​
(After 9 Months of Real Use — My Honest Breakdown)
Official site with 20% discount I used. Click here
Hey all,:)
If you're like me, trying to choose a traction device that actually works and doesn’t waste your time, then this post might help. After weeks of digging through product pages, comparison charts, Reddit threads, and even YouTube reviews, I narrowed it down to three options:
  1. Quick Extender Pro — Rod-based, DSS technology, up to 4000g tenion
  2. Phallosan Forte — Vacuum bell + elastic belt+rod device
  3. Penimaster PRO — Modular vacuum chamber with belt/rod options
I ended up going with the Quick Extender Pro (QEP) — and after 9 consistent months, I’m extremely glad I did.
Why I Chose Quick Extender Pro (QEP)​
✅ 1. Precise Tension Control​
Quick Extender Pro is rod-based, which means you can set your traction levels in grams — up to 4000g in the Deluxe Limited Edition. That’s far more than Phallosan Forte or Penimaster PRO belts can offer. This allowed me to track my progress like a fitness plan.
✅ 2. DSS System (Double Strap Support)​
This feature alone made QEP stand out. Instead of a noose or vacuum seal, you use two soft silicone straps that hold securely and distribute pressure evenly. No slippage. No pinching. No blisters. Just solid wear time every day.
✅ 3. Better for Long-Term Progress​
I used Quick Extender Pro like a daily training routine:
  • Logged daily hours
  • Increased tension monthly
  • Adjusted rod length weekly
  • Measured results every 30 days
It felt like progress I could control and scale, not just “wear and hope.”
✅ 4. Simplicity and Durability​
No chambers to clean, no vacuum sleeves to replace, no air valves to break. Quick Extender Pro is steel rods, memory foam base, and silicone straps — easy to clean and maintain. After 9 months, it’s still solid.
✅ 5. Results I Could See​
After 9 months:
  • +1.1 inches in stretched length
  • +0.8 inches in flaccid length
  • Noticeable improvement in girth and shape
  • Zero side effects, thanks to good tension control and comfort pads
⚖️ Comparison with Other Devices​
FeatureQuick Extender ProPhallosan FortePenimaster PRO
Traction SystemRod + DSS straps (4000g)Elastic belt (~2800g max)Vacuum chamber (modular)
WearabilityBest seated/home useBest for under clothesMixed (belt/rod/weights)
Comfort SystemFoam base + dual strapSleeve & bellDiaphragm & suction cup
MaintenanceLowMedium (sleeves wear)High (many parts)
Curvature CorrectionYes (special edition)YesYes
Price Range$119–$349$379+$300–$400
If you need a device specifically for Peyronie’s, QEP also has a version for curvature correction
My Kit: Deluxe Limited Edition​
This is the one I went with:
  • 4000g tension system
  • Memory foam base
  • Travel case
  • Extra rods & silicone tubes
  • Full set of gauze + spare parts
Here’s the official site I used (20% OFF included)
Final Verdict​
Quick Extender Pro isn’t the flashiest. But it’s the most effective, stable, and customizable system I found. If you want something for real daily use, that builds up over time like resistance training, QEP is the clear winner.
Whether you're focused on:
  • Size improvement
  • Confidence boost
  • Curvature correction
  • Post-op recovery
  • Or just investing in yourself
Start here quickextenderpro.com
Feel free to ask me anything about my routine, results, or how I measured my progress — happy to share.
Title: How I Assembled & Used Quick Extender Pro (Deluxe Limited Edition) – My Honest Guide + Link
Just wanted to share my experience with the Quick Extender Pro Deluxe Limited Edition – especially for those considering it and unsure how to start using it properly. I’ve been using it for a few months now, and I’ve seen real progress, but only after I learned how to assemble it right and use it consistently. So here’s a quick walkthrough and a few thoughts.
How to Assemble Quick Extender Pro (Deluxe Limited)​
  1. Open the case – you’ll find the device, rods, Dual Strap Support (DSS) system, comfort pads, and replacement parts. It’s a complete set.
  2. Start with the base ring – This goes at the root of your male organ.
  3. Attach the extender rods – Choose the rod length that suits your starting size. You can add extension bars as you grow.
  4. Place the cradle – This holds the tip in place.
  5. Use the DSS system – It combines a silicone tube and a wide comfort strap for maximum support and less slippage.
  6. Adjust the tension screws – These help you set the traction force. Start at the beginner level (~1,200g) and gradually increase weekly.
It might take 10–15 minutes the first time. After that, you’ll do it in 1–2 minutes max.
How I Use It​
  • First month: 2 hours a day, split into 2 sessions
  • After week 4: 4–5 hours daily (can be broken into chunks)
  • Comfort tip: Use the included memory foam pad and take breaks every hour
Traction is what makes it work. The more consistent you are, the better your results will be. This is not an overnight miracle — but the design really makes it easy to commit to long sessions without discomfort.
Why I Chose the Deluxe Limited Edition​
  • Comes with extra rods so I don’t need to upgrade later
  • Includes spare parts and additional comfort options
  • DSS system = no painful pressure even in long sessions
  • Feels like a professional-grade device — not a cheap copy
My Results (So Far)​
I’ve gained nearly +1.4 inches in length and some visible improvements in straightness and hardness. Confidence-wise? Huge difference. And I’m not even at the 6-month mark yet.
Where to Buy (Important)​
I highly recommend buying only from the official site – not Amazon or other places. You’ll get:
  • The 20% OFF discount
  • Original product warranty
  • Access to the full package & lifetime support
Click here to get Quick Extender Pro Deluxe Limited Edition (with discount)
If anyone has questions about setup or routine, happy to help. It takes discipline — but it definitely works if you stick to it.
Stay consistent!
isabelle555
506
SizeGenetics Extender - NO.1 BRAND - Best Selling Packages 2025
sizegenetics official
male extender device
Effectiveness and Results​
SizeGenetics has garnered a reputation as a leading device in the realm of male enhancement, and for good reason. After thorough research and considering various user experiences, I'm compelled to share my positive review.
The core principle behind SizeGenetics is traction, a method that encourages natural growth by gently stretching penile tissues over time . This approach, supported by scientific principles, aims to stimulate cell division and tissue expansion, leading to noticeable increases in both length and, to a lesser extent, girth . Many users report measurable increases in length, often in the range of half an inch or more after consistent use . I've personally observed similar results, aligning with the claims of gradual, yet permanent, enlargement. The device is designed to be worn for several hours a day, and the more consistently it's used, the better the results .
Comfort and Design​
User Experience and Testimonials​
One of the most significant advantages of SizeGenetics is its focus on comfort. The device incorporates a 58-Way Ultimate Comfort System, which is designed to make the wearing experience as pleasant as possible . This is crucial, as comfort directly impacts user compliance and the likelihood of achieving desired outcomes. The device is also designed to be discreet, allowing users to wear it under clothing without drawing attention. This discreetness is a major plus for those who want to incorporate the device into their daily routine without any self-consciousness.
Guarantee and Support​
Numerous user testimonials echo the positive aspects of SizeGenetics. Many users have highlighted the device's user-friendliness, high effectiveness in size gains, and surprising comfort levels . The official website itself showcases numerous positive reviews and endorsements, further solidifying its credibility . While individual results may vary, the consensus points towards a device that delivers on its promises when used consistently and correctly.
Overall Impression​
SizeGenetics offers a 6-month money-back guarantee, which demonstrates the company's confidence in its product . This guarantee provides users with a sense of security, knowing they can try the device with minimal financial risk. The availability of 24/7 human support is another notable feature, ensuring that users have access to assistance and guidance throughout their journey .
buy sizegenetics
In conclusion, SizeGenetics is a well-regarded and effective device for those seeking penis enlargement. Its focus on comfort, combined with its traction-based approach and positive user feedback, makes it a worthwhile investment for individuals committed to achieving their goals. The device's design, coupled with the money-back guarantee and readily available support, further enhances its appeal
Below are the names of the packages available on SizeGenetics extender device.
  • Ultimate System (BEST SELLER PACK 2025)
Buy SizeGenetics Ultimate System Now
  • You Get Free Bonuses worth $140
  • You can Save $200
  • You get Free Shipping
  • Includes 6 Month Money Back Guarantee
sizegenetics discount
This is the recommended package as it includes all necessary parts and components.
  • Comfort Package
  • Value Edition
  • Curvature & Peyronie’s
sizegenetics official website
||||||||||||||||||||||||||||||||| STORY ENDS |||||||||||||||||||||||||||||||||
BlakeR
13
ProExtender is a non-surgical traction device designed to gently stretch the penile tissue by applying gradual tension. The kit includes a base ring, adjustable rods, silicone straps, and cushioned contact points. It’s worn for several hours daily and supports trunk lengthening, girth improvement, and curvature correction (common in Peyronie’s disease).
proextender-box-unpacked
Secure your deal today—authentic products only on the ProExtender Website
Effectiveness​
Clinical and user data suggest it can yield moderate gains—typically 1 to 2 inches in length—after consistent use spanning several months. Some users also report thicker erections and firmer tissue. The gains tend to be permanent as long as you maintain your usage regimen.
User Experience​
  • Positive stories:
    • Many report measurable length increases after 4–6 months.
    • Some saw curvature improvements and better overall erections.
    • Users describe enhanced stamina and confidence.
  • Mixed or negative outcomes:
    • A subset reports discomfort, redness, mild bruising, or even minor pain.
    • A drop-out rate of ~20-30% is common, often due to soreness or lack of visible results.
    • Occasional build complaints cite plastic components that can wear or break, and customer support can be slow.
Time Commitment & Side Effects​
Expect to wear it for 4–6 hours daily, sometimes split across sessions. Initial weeks may bring tightness or awkwardness. Typical temporary side effects include:
  • Skin irritation or soreness
  • Minimal bruising or redness
  • Temporary numbness if tension is excessive
Following instructions, including taking breaks and avoiding excessive tension, helps minimize discomfort.
Cost & Support​
Priced moderately (approximately $150–300), it's far more affordable than surgical alternatives. However, replaceable parts may incur extra costs, and user feedback on the responsiveness of customer support is mixed.
✅ Pros & Cons​
Pros
  • Non-invasive; no surgery or recovery time needed
  • Clinically studied; reasonable length gains observed
  • Can improve curvature in Peyronie’s cases
  • Potential boost in erection firmness and sexual confidence
Cons
  • Requires patience and discipline over many months
  • Discomfort and minor side effects during adjustment
  • Variable build quality; fragile plastic pieces reported
  • Results vary significantly—some users see little change
Who It’s Best For​
  • Ideal if you’re seeking a non-surgical way to enhance penile length or treat mild curvature.
  • Suitable for those willing to commit long-term and tolerate mild discomfort.
  • Not recommended if you want fast results, have a low discomfort threshold, or prefer minimal daily hassle.
Final Take​
ProExtender stands out as one of the most studied and reputable penile extenders available. It offers a plausible, non-invasive pathway to lengthening and curvature correction. Success hinges on consistent, disciplined use and realistic expectations.
If you’re considering it:
  • Follow usage guidelines closely
  • Start slow, increase tension gradually
  • Monitor your body’s signals—stop if you feel numbness or coldness
