ZT2 Wideband Questions
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
isnms said:
do you have any data logs you can post?
for now you'll have to zip it. I've sent a message to IdealSupra to see if he will include the zto extension for attachments :)
here is a short sample of one of mine
http://www.supramania.com/forums/attachment.php?attachmentid=26
You could always do a print screen of a portion of a log. Has anyone messed with the excel export of data? I haven't gotten a solid data set yet.
I am getting quite a bit of electrical interference causing my lap top to act up at times.
Yesterday rpm readings where right on but I was showing negative percentage for throttle at times. -5 was the reading at idle, has anyone seen that happen?
I'm always right around 14.5-15 at idle except when first started (13 or so due to cold start circuit) I have a techtom ecu and have seen as rich as 9.7:1 under boost so far, I need some serious map altering. I have a 440 chip but run 550s/Lex AFM.
Once it's all squared away and the bugs are worked out, I'll compare with my stock ecu for everyone.
Brian W-88T
