Would I regret removing TEMS?
Supra90gr
116
Connecticut
Has anyone removed there tems controller? Does it help at all? Does it change the handling of the car? I want to do coilovers but I'm debating because of the TEMS. What do you guys think?
cinciguy89turbo
Zero to Sixty
Apr 7, 2009
139
Cincinnati, Ohio, United States
I went from a car that had TEMS to a car that doesn't, and I honestly haven't noticed that much of a difference. The cars had over 130k miles though so its possible that the parts are so worn that I just can't tell the difference.
Cz.
CAR > FAMILY
Seattle, WA
If you're changing out the suspension, the TEMS system isn't going to be doing anything anyways. It's only applicable if you get the stock TEMS shocks or the Tokico Illuminas.
Supra90gr
116
Connecticut
Well i want to get the tokico illuminas but i'm thinking about the HP's now for budget reasons. I have whiteline sways front and rear and I'm going to be running MK4 turbo wheels. So handling should be good. If I disconnect the tem actuators will the LED's for the tems on the dash bug out all the time?
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
they wont come on. tems isnt really worth keeping. any aftermarket suspension should be better than what tems could hope to achieve on its firmest setting
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
yeah, my 89 and 92 don't have tems, but the 86.5 does, and I don't notice any drastic handling improvements..
but of course, that could be due to the fact that the damn car is 23 years old, I bet if I got all new bushings, tires, struts, springs, etc she'd handle like a go cart..
we'll see..
rayall01
901
Westfield, ma
Before I replaced my struts and springs, The car was unsafe to drive over 100 mph, after, I've had it up to 140 so far, and it's solid as a rock. This is with original bushings all around. For my money, the Tokico Illuminas work great, and so does tems.
Comparing blown TEMS to new non-TEMS isn't a fair comparison.
My car didn't have it and I even looked into retrofitting it as it's a luxury GT car and TEMS is nice for cruising.
If you're going to gut your car and race it, ditch it, if you want a nice comfortable car, keep it.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
+1 listen to poodles
Cz.
CAR > FAMILY
Seattle, WA
You don't have to keep the TEMS to have a comfortable car, the springs have just as much importance on that aspect as the shocks do whether or not they are TEMS compatible.
Doward
4,245
Alachua, FL
That'd be me! I LOVE the TEMS system. Working, good struts makes a noticeable difference when doing high speed cruises. There was a noticeable difference in firmness between the three settings on my '88 with good, working TEMS shocks.
FIL
227
Thornlie
blog.highoctanephotos.com
just get some new shocks that actually suit the way you drive and the roads you drive on... they'll be much better suited to your application than even brand new TEMS shocks would have been...
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
I swapped out my new illuminas and eibach blues into my '90 with no tems. I just left them on the firmest setting. It seems to handle quite well for a low cost alternative. I didn't seem to miss the adjustment was my point.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
They are expensive, but you can still have high quality coilovers with adjustable shocks. Tein Flex with EDFC (electronic damping force controller). I cruise on the softest setting and crank up the firmness for aggressive driving.
rayall01
901
Westfield, ma
If I could afford coil-overs, that's the setup I would get. They are very expensive though, especially with the EDFC
dogdrake
148
Gadsden Alabama
I went from worn out stock tems to the tokiko illuminas and ebach springs it was a huge difference and even better with the front and rear suspension techniques sway bars it's bad ass. You won't regret keeping tems if your planning on daily driving . If all you do is autocross its a different story coilovers would be better so you can transfer weight.
