wiring woes na-t 87 gte eletronics into 90 na shell
koreyd
172
fall river mass
http://www.facebook.com/album.php?aid=267249&id=540960592&saved#/photo.php?pid=10898390&id=540960592
this is the b1 plug off of the 87 turbo harness i have no idea where these plugs are supposed to go.
http://www.facebook.com/album.php?aid=267249&id=540960592&saved#/photo.php?pid=10898393&id=540960592
this is b1 plug off the 90 na harness which i am using. it has been pinned form the 87 harness.
http://www.facebook.com/album.php?a...p?pid=10898394&id=540960592&fbid=473694315592
i think this b3 plug off the 90 na engine harness hasn't been repinned yet
also is the m1 connector on the 87 turbo harness the sameas the m1 connector from the 90 na body harness. they are pinned with the same colored wire and are the same clip. are these plugs actually different
http://www.supras.nl/index.php?option=com_content&task=view&id=34&Itemid=50
i am using this website to do my rewire. i am trying to ingore all the info on swapping the jz plugs.
koreyd
172
fall river mass
87 b1 i can't find info on where these wires go to
90 b1 aka ih1 maybe. pinned from the 87 egnige harness
b3 not repinned yet
i have been usinghttp://www.supras.nl/index.php?option=com_content&task=view&id=34&Itemid=50as my refernece site
what motor is this for? so you have like 8 or 9 wires that dont have a place to go?
i might be doing this soon for someone and was planning on using that site.
koreyd
172
fall river mass
the ones i am having trouble with are the four wires in the b1 yellow connector from the yellow 87 turbo harness
the white - green and the white-red on the b3 connector from the 90 na harness
last but not least the blue - white wire from the three pin connector and thats it
anybody have a clue. please help
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Little 3 plug you wanted to know those two wires.
1. #160 A/C water temp s/w no. 2 Blue – white
2. A/C water temp switch Green - Red
Last pic is for ABS
koreyd
172
fall river mass
oh the car was a 90 na
the na-t using 87 gte turbo,
now going to setup the 87 turbo electronics using all of them and the 87 ecu
just trying to get the body connectors on the 87 turbo engine harness to match up to the na body harness.
i am about 98 % done. hopefully it will be ready to put in the car and test shortly
koreyd
172
fall river mass
92 tealsupra
ok i understand what they are for now but what i don't understand is where they are supposed to be wired in the 90 na dark grey clips
i can't find these answer on the supra.nl site
all i have left are these wires and the coilpack rewire which i had help on from another post on supramania.
92tealsupra - any clue about the last four wires on the b1 yellow connector. where they go
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
koreyd;1505357 said:
92 tealsupra
Go to my site.
koreyd
172
fall river mass
on;y three wires left b1 yellow brown and white - blue
i see that the brown wire runs to the hac sensor which i will use. i believe that once i wire the vpc the hac sensor will be resistors in the feilds harness
the white and blue wire is for injector 1 and 4. my guess is a check connector or something that to the combination meter
and the a/c switch two wire off the two wire connector i can't find where is goes and that is the end of my questions about the body connector repin
when you figure these out would you mind posting it as im doing the complete opisite with 89-90 harness into a 87.
koreyd
172
fall river mass
i only have three wires left the brown out thte b1 and a white with a blue stripe and blue with a white strip out of the two pin connector
yeah thats what im going off. what did you do with the white- blue and red-green off the b1?
so these are the wires im missing where they go
blue-black on b1 on the 89 harness (theres 2 on the 89 and 1 on the 87)
white-blue, brown, red-green on b1 on the 87 harness.
red-black, brown, blue-red on the hac connector for the 87 harness.
blue-white for the b4 on the 87 harness
any ideas?
thanks.
