Is there a guide on what means what on the VIN number? Specifically which digit is turbo/non and is there a digit for transmission?
hvyman;1843388 said:
te72;1843458 said:You might find whether it was a JZ, G, or M car from the vin, but I don't think you will find transmission info on our cars. All Mk3 North American vins will start with JT2MA7. The next digit would either be a 1 or a 0, depending on turbo or naturally aspirated. The 8th digit in the vin, I'm not sure what that signifies on our cars. Mine is a J, have no idea what that means. The rest is plant and serial number.
hvyman;1843669 said:Diff and trans are on the door jam. If it had r154 it was turbo car.
te72;1843652 said:Man, your local dealer must be a lot cooler than ours...
