"Turbo A" Replica?
What engine?
  • 2JZ-GTE
    Votes: 15 30.0%
  • 1JZ-GTE VVT-i
    Votes: 8 16.0%
  • 7M-GTE"U"
    Votes: 12 24.0%
  • Twin charged(?) 1UZ-FE
    Votes: 10 20.0%
  • 2Jz-GE NA/t
    Votes: 5 10.0%
  • Total voters
    50
Does anyone know what I would have to do to my 7M to have it replicate the Turbo A stats?
I am doing a swap regardless, but I'm contemplating inbetween the 1JZ-GTE VVT-i, 2JZ-GTE, 7M-GTE"U", and the 1UZ-FETT[SC?] :3d_frown:
Whatever gets the most votes wins, so vote and keep an eye out for the build thread. :icon_surp
martin p
1JZ-GTE powered Supra.
Feb 5, 2006
215
East coast. UK
Turbo A= different 3000 pipe(larger bore and different design) different throttle body(larger bore) runs Map not Maf So no AFM,i think the turbo is slightly larger too (not 100% sure on that). unique body graphics and rear badge, anthracite colored saw blades,
Oh and right hand drive.:naughty:
IJ.;1414628 said:
In all seriousness a 2GZ-GE NaT makes a lot of sense in your position, might want to consider that an option.
I had that priced out as follows
2JZ-GE-$999 + Shipping
'86-'89 1JZ/2JZ swap motor mount brackets - $149
'86-'88 solid motor mounts- $120
1JZ/2JZ to W58 Bell Housing- $335
1JZ/2JZ W58 Flywheel- $275
ARP 1JZ Flywheel Bolts- $30
ACT Stage 4 W58 Clutch Kit - $470
W58 Transmission Rebuild Kit-$210
GREDDY Speed Cut Defender for 1JZ/2JZ- $75
2JZ-GE Complete Engine Gasket Set-$295
Total = $2958
It really does seem pretty good, but I know that setup needs some tweaks. Care to bring it into proportion lol?
The beauty of it is it'll run fine on the 7M electronics until you can afford management down the track so makes a good bare bones type swap.
The other choices will need a big investment in time/cash to make run at all.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
Why would he want a V12 that's nearly impossible to find?
ooooooooohhhhh, you meant 2JZ-GE, not 2GZ-FE.
I wonder if that guy putting the 2GZ into the MkII ever finished...
To add in my opinion on the topic, follow the road most travelled with a JZ swap if you're not electrically inclined. Almost every aspect of the swap is well documented, so it's not rocket science. Otherwise, roll the dice with a 7M build.
Going with a twin turbo 1UZ will involve a rediculous amount of custom fab, alot of headaches, set backs, and creativity. A 7M build or JZ swap will only have alot of these things...
