When I reach 1bar of boost, it's like hitting a fuel cut or revlimiter.
The rpm arrow on the tacho begins to randomly jump from 3000-7000 rpm,
or sometimes at full throtlle hitting 1 bar of boost and 4000rpm in second gear tacho stops @ 4000 rpm mark and speed slowly keeps on rising with a huge loss of power.
If I set max boost to 0.8 bar, nothing wrong happens, everything is smooth and fine.
Almost everything connected with ignition is changed, but still no results.
I`m shure that the problem is with the ignition
but don`t know where
all the wiring checked twise still nothing
Engine 7m-gte `91
mods:
ARP Pro Series Head Bolts
Clevite Main & Rod Bearings
Wiseco Pistons & Rings - 7MGTE - 84mm Bore, .040 Oversize, 9.0 Comp Ratio
Eagle H Beams 4340 Forged Chromoly Steel Connecting Rods
Fidanza Built To Fly Flywheel
RPS Bronze Stage 5 Clutch Kit (Sprung Disk)
Titan Motorsports Head Gasket (Stopper style), 2.0mm
Toga High Volume Oil Pump
//Powerhouse Stainless Exhaust Manifold
Garret GT40
Greddy iridium sparkplugs 9
40mm UnKnown Wastegate
Custom Cooler & Piping
Spearco Intake
Custom 3` Exhaust
PIT Blow off Valve and Flange
Walbro 255lph Fuel Pump
WR Adjustable Fuel Pressure Regulator
RC Engineering 750cc Injectors
Tein Super Street Suspension
Stop Tech break Pads
AEM standalone
:1zhelp:
Engine 7m-gte `91
mods:
Garret GT40
Spearco Intake
Custom 3` Exhaust
AEM standalone
:1zhelp:
