Stock VS. 3" Exhaust Difference?
jdemara
285
North Delta
Ill start by saying I have a stock 7m-gte, with the exception of a SSQV and shimmed wastegate at 9psi.
Just curious to know how much horsepower is added going from the stock restrictive exhaust, to a full 3" exhaust off the turbo (including elbow and DP).
Does anybody have before and after dyno results?
Also, how much does it usually increase the boost? Any fuel cut issues (with a non-shimmed wastegate actuator)
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
first thing i did was upgrade to a 3" exhaust... very noticeable difference. increases boost about 1-2psi
then i did the downpipe and elbow and that increased boost by another 2psi
i feel that exhaust and intake should be the best bang for the buck in the early stages of upgrading a stock mk3.
no i didnt hit fuel cut... but no two cars are identical so that doesnt mean that you wont
jdemara
285
North Delta
Doward;1287199 said:
No single thing made as big a difference on my car.
Dead serious about that.
that is AWESOME to hear! can't wait to get mine done!
anybody have dyno numbers to see the increase in horsepower?
Considering I shift at 2K RPM and start spooling at 1500 RPM... All because my exhaust.
Anyone that says that you'll lose bottom end torque is WRONG.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
Spend $25 on a DrJones Manual Boost Controller, and take the shims out of the wastegate. My car got 12-14 pounds of boost out of a Meagan downpipe 2 1/2" inlet, 3" the rest of the way out of the car, intake, and MBC. I may have gotten better, but hit fuel cut usually around 12 1/2 PSI. Then I usually had to back down the MBC a tad.
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
Yeah I started with an intake then upgraded to a 3 inch downpipe and 3 inch cat back and it was like a whole new car, im not much farther in my upgrades and im still pretty pleased.
best mods to start
1. Intake
2. Exhaust downpipe and elbow back to the end 3 inc hor bigger
3. boost controller
then go from there......
edmonton
24
edmonton
getting my ddp and 3" piping all the way installed... cant waitttt!!
oh and 5" exhaust with removable silencer
vroom vrom
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
vroom vrom
I take it you mean 5" tip on the tail pipe? Or do you mean 5" from the turbo back :biglaugh:
