Is the bolt with the nipple below it that Im pointing to in the pic a coolant line or a oil line? Is it a feed or return? Im going to run stock twins and need to tap it in somewhere.
![p1657290_1.jpg](https://www.supramania.com/images/pb_archive/p1657290_1.jpg)
JZ_n_It;1657540 said:stick to the nonturbo parts with respect to the oil filter housing and run a sandwich plate for your oil feed and any oil sensors you want to run.
aphxero;1657767 said:Yeah those are coolant lines through the oil housing. A ge block has them you just have to change a plug with the pipe. For oil I just tee off from the oil pressure sensor port with a -4an. The threads in the block are 1/8 bspt which is easy to adapt then run a line right around the front of the motor.
aphxero;1658444 said:oh it looks like you have the newer type motor with the bigger threads in the oil sender. It's that one right in front of the oil filter with the one wire connector. They aren't 1/8 bspt like most toyota. I had one of these and iirc it was like 10x1.25. I was just saying go to hydro shop for getting lines and fitting stuff.
But yeah measure those threads. And it looks like in the pic the allen plug for the other oil cooler line is still in the block?
aphxero;1658731 said:nah the stock turbo hardlines go into the block on the exh side. btw, dbb=ball journal=regular turbo. I got some pics coming.
