Scion T1807/T1806/T1808 Installation
Devin LeBlanc
1,830
Las Vegas NV.
I recently acquired a Scion XB OEM radio (faceplate part number T1807) I decided I would install it in my supra to replace that 22 year old vintage cassette player :nono:
Here is the way I installed it and it came out looking really nice. Feel free to ask any questions!
Thanks,
Devin
First off I started by removing the radio trim piece along with that pesky old stock radio.
I removed the stock radio brackets from the old radio. They needed to be modified a little to work with the Scion radio. I used tin snips to trim off the appropriate amount of material so it would clear the front of the radio. All the screw holes and line up pins are the sam.
Note: On the drivers side of the radio I left the back bottom screw out as it does not clear the dash support. However you might be able to wiggle it passed it. I just left mine out and it slid right in without it in.
Here are the two trimmed brackets mounted to the Scion replacement HU.
Next I used a dremel tool with a sanding drum attachment to carefully remove plastic surrounding the radio front bezel so it clears the dash.
Before:
After:
I then installed the Scion HU into the supra. The Scion unit has a total of 4 plugs on the back. The appropriate stock supra wiring harness 6/10 pin plugs will plug right into the back of the radio. On my Supra there are two antenna wires, one is a bigger plug than the other. The scion radio has both the plugs on it however the smaller one is hidden above the bigger one behind a piece of metal part of the casing on the radio. I just bent back the cover over it and snipped it off so I could access both antenna plugs.
And a personalized start up text.
The next step was to trim away some of the material on the radio bezel that covers the radio and shifter. I used a brand new sharp razor blade. I recommend doing this as you'll get a nice clean cut and wont have to struggle with a dull one. I have drawn lines in red of the material and parts I removed shown in the pictures. Doing this will allow the power and eject buttons to clear the bezel along with removing the side pieces so that the radio will clear inside as the scion radio is a little big bigger in width. Same height though.
And last, Once the bezel is trimmed reinstall it. Here is the finished product of my install. Pretty good.
Hope the helps some people in the future. Thanks for looking!
SrBigbutt
340
Spring, TX
Looks awesome. Maybe you can find a way to get rid of the Scion logo. Since you seem to be pretty good with details and paint.
Devin LeBlanc
1,830
Las Vegas NV.
That was the next step, Im not sure how maybe lightly sanding untill its gone, otherwise trying some chemicals might take it off. But I would be afraid about ruining the face plate.. So for now it stays :p I'll just get a vinyl cut with the mk4 style supra front that says Supra. That would look pretty good.
maj75
Miami, FL
Any way to change the lighting? It bugs me when the radio lights don't match the dash lighting. It's not that I am so much of a green lighting fan, but I want it all consistent and since everything else in my dash lights up green, I want the same on the radio.
Devin LeBlanc
1,830
Las Vegas NV.
The T1808 has the option to change the colors to about 12 different ones. But the T1807 as I have does not have the option to.
Today I made a custom aux cable so I could hook up my ipod and use it. Heres how it turned out! Very clean looking to me.
Custom Auxiliary input wire made. 2.2 Ohm resistor made in between the ground so give the signal to allow the aux function to be available.
Mounting 1/8th inch stereo panel mount jack:
All Done, Came out looking nice!
Devin LeBlanc
1,830
Las Vegas NV.
Try lining up the bolt holes on the bracket. You will notice you have to move the bracket forward towards the radio faceplate. I trimmed about 4-5mm off mine which allowed just enough for it to sit right up against the back of the plastic radio face
Devin LeBlanc
1,830
Las Vegas NV.
I have no idea.. It all depends on the mounting hole spacing and plugs. I'll try to do some research and see though. Glad its working for you RougeSteel.
maj75
Miami, FL
Would you be willing to part with your stock radio? I am looking for one to replace the one I have that stopped working.
tremonti23
utah
Hey i have been wanting to do this to my t1808 could you give me a list on what i need and how to put it together? i would really be grateful.
