safc and fcd installed together or no
Vlads2jz
Cleveland
rayall01;1351640 said:
I posted this earlier, on a similar thread:
Well, you're also hoping for a blown head gasket, rod knock, and maybe even a hole in your piston. How many times do you have to read that a FCD is a time bomb waiting to go off, before you get it? Fuel cut keeps you from doing something dumb, and blowing up your engine. Go ahead, use the damn thing, and while you're at it, remove the brakes too. They just add needless weight, right?
NO FCD!
You crack me up. I guess if your a dumbass then yea it will blow up.
From what I see FCD and SAFC cannot be used together. It doesnt even make sense for them to work together. Both of them work by altering the signal to the MAF or MAP.
Beals
JZA70 TT-R
Feb 3, 2009
591
Alberta, Canada
rayall01;1355788 said:
It should be set in the garbage.
hahaha, you crack me up man.
But yeah I was kind of wondering about that, because the SAFC and FCD go in about the same spot. But yeah I'd have to say I learned quite a bit just from the arguing going on. lol
