hey
ok so heres what happened.... a month ago i had to do a head gasket replacement, I replaced it and reinstalled everything without a problem and installed everything according to the book,everything worked out great! cams were at TDC and so was the crank pulley, i followed the TSRM to assist me with the reassembly.
-now heres my issue, my rpms are boucing under 1k and the car shakes, also, when i floor it the car does not respond as it used to:nono:, i checked my timing and it was WAAAAAY off so i went out and got a timing light and attempted to set it, noticed that i cannot set timing at 10 degrees as the TSRM tells me to, i figured its my ignition so...
-i replaced the rotor for the distributor and replaced the ignition coil, and im still having the same issue :icon_mad: i set the timing as close to 10 degrees without it stalling, im getting shitty ass gas milage too
can anyone help me or give me some pointers...thank u in advance
i have a 94 supra NA auto, bone stock, no engine mods and it has 178k
-Tony
-Tony
