Race Ready 7M
thedave925
Since 9/16/05
Nov 9, 2005
626
East Bay, Cali
Coolant is chemicals with pH levels, that change as they react. The reaction can create low voltages. Like a Lead plate battery.
Seems your looking to slow down the reaction, while tying it to affecting the ground of the TCCS, which the TCCS measures for values during operation.
A valid point when looking at random misfires, but ignition break-up seems far fetched.
What I'm getting at is don't drive yourself up a wall over a moot point ;)
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Van;1712503 said:
Here are the values for the Koyo "Race" Radiator: .002mV and 1242 Ohms; Coolant in Rad: -0.17mV (all done w/ignition on). I tested the Rad w/o the ignition on and the mV values were so low: -12.0mV.
Again, I'm not sure what these values mean for the life of the Rad. Are these values ideal? Van
Sorry for the delay in replying Van...
What is the resistance reading from the rad itself to the negative battery terminal. From the coolant voltage reading, I'm going to guess that it's pretty high. In the Meg-Ohms. Which is what we want!
Hey Dave. We're just trying to get the rad isolated. ;)
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
Hi Kenny,
Tested at 8:10PM, OAT 58 degrees; Value for cold Rad to Bat -: 627 ohms (ignition off, using 2000 Ohms scale). Van
---------- Post added at 08:21 PM ---------- Previous post was at 08:18 PM ----------
sunnysupra;1713993 said:
nice build!
Thanks! It's been quite an experience... Van
CajunKenny
Nov 15, 2007
3,255
Washington
Van;1714012 said:
Hi Kenny,
That's a HUGE improvement; but, can still stand to be a bit better. Try taking off the top clamps and let the rad lean toward the engine and then see what the resistance reading is. We're getting closer! :D
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
Kenny,
Thanks for your feedback... Tha Rad isn't touching anything except rubber; Test time 8:20AM, OAT 47, Raining, Rad to Bat-: 487 (scale 2000 ohms). Ohms kept climbing, slowly, after three minutes it reached 487. Van
CajunKenny
Nov 15, 2007
3,255
Washington
487 - 627 ohms might be the best we'll get. Mine reads 1.2 meg ohms; but, I went through great lengths of isolating mine.
Now we just need to get your bigger rad to be as isolated as your koyo. :)
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
O.K. Kenny, are those values WNL?
In an earlier post I stated that the millivolts running through the Rad were negative...
What does that mean? Van
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
I love the hour glass body (artistic photo)
CajunKenny
Nov 15, 2007
3,255
Washington
I don't know what the normal limits are. I can only go off of my car. Maybe someone else can go take some measurements and post up their findings. I'd be curious to know.
I remember JetJock stating somewhere that around 50-60 millivolts between the coolant in the rad and the negative battery terminal was desirable.
When I first tackled this beast, I had mine down to 48 mV. Mine is currently at 68 mV with a resistance reading of 1.2 meg-ohms.
In the case of your negative voltage reading, a negative vs positive voltage reading deals with probe polarity. Basically, you had the probes switched around. ;)
I agree with you! :D
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
IJ.;1716915 said:
Below 50Mv is desirable, you can't do this test with a DMM though due to the way they read has to be an analogue.
Thanks, IJ. I'll take it over to Auto Electric Specialties to have them test it on their analogue MM. Van
---------- Post added at 11:04 PM ---------- Previous post was at 10:59 PM ----------
So, Black probe on the Bat-, Red probe Rad, is what I have been doing all this time...:3d_frown:
CajunKenny
Nov 15, 2007
3,255
Washington
Thanks IJ. I'm glad my memory hasn't gone way of the dodo...
I'm not differing with you here IJ because you are correct; but, the difference in readings between the two meters should be slight. Well...depending on the age and type of his meter anyway... ;)
If you can get them to do this, have them do a comparison test between an analog and digital meter, and post up the results. I wouldn't do it if they're going to charge you extra for that though.
It's all good. We just needed the number. Polarity isn't important here. :)
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
Here is a link to an album on Picasa showing the current Rad set-up: https://picasaweb.google.com/raceready7m/AlumRad?authkey=Gv1sRgCIXk0seMrpeUWQ&feat=directlink
I made sure the brackets are isolated and will maintain the rubber pads in alignment. If a bracket starts moving out of alignment, my plan is to make new brackets w/extended bases and use threadcerts and a screw through the back, in the stock hole for the alignment tabs on the stock brackets. Van
