Simply, has anyone looked into doing a swap for an A350E / A650E as used in the GS300's?
Would they be likely to be compatible with a 7M bellhousing?
a650e Gear Ratios: 1st 3.357 2nd 2.180 3rd 1.424 4th 1.000 5th 0.753 Rev 3.266
a340e Ratios 1st:2.804 , 2nd:1.531 , 3rd:1 , 4th:0.705
Nah there isn't one I can find online but you could check some of the Lexus forums I'd guess it's out there!Kai;1478089 said:LOL - PDF for the A340/350/650 etc
I have the A340E section in the TSRM here, so i can use that as a base.
Seriously starting to think this is an option for the old, tired 122k mile A340E thats in there. I was just going to get a filter and new fluid in there, but i'd want to replace the solenoids etc.
The other option i was considering, was overhauling the A340E in there, but even though i'm fairly sure i have all the tools i need, it looks VERY fiddly.
It will lower your IQmkIIIman089;1478104 said:Definitely subscribing to this one!
"Cable" has very little to do with shifting it's only Line pressure, shifting is dependant on the TPS so check that's adjusted correctly.Kai;1478108 said:Type 4 - got it
Any idea on the Q?
Yep I'd say 3.2:1 would be a good start to load up a Turbo motor.mdr40z;1478109 said:so even the 3.42 from Jaws would probably be low.
the boxes look pretty darn close, if the BH swaps looks like it could be just a custom converter
