^ Thanks, yeah block wasnt resurfaced. Using Titan 1.4mm MLS gasket, holding up pretty good, OEM blow off valve isnt connected to anything right now I havent removed and covered the ports yet, im not running the Bosch platinums anymore but oem DENSO from Toyota, expensive per plug but worth it. As for the clutch it feels stiffer than the OEM i had in it before doing this, and im only using it for street use with moderate HP upgrades so shes fine.
