I thought we should have a Haltech specific thread here so if you guys have any questions or experience with Haltech EMS's it will all be in one place.
BIC Performance is an official Haltech dealer and it is our EMS of choice. I have the New Platinum Sport 2000 ECU in my own car and have installed and tuned many on our customers cars. There is a P&P harness available for the 2jzgte MK4 Supra using the PS 2000 EMS, and now recently released a brand new fully terminated harness for the 2jz using all new wires, connectors and plugs and plugs right into the ECU.
BIC Performance has just finished testing our prototype Jumper Harness to adapt the Haltech Sport 2000 ECU to stock 1JZ engine wiring. We are hoping to have our first production harness built and tested in the next two weeks. Installation will take only a few minutes and will be loaded with a base map that will allow initial engine start-up. The best part is that there is NO wiring necessary, simply plug in the jumper harness to the engine harness and Haltech ecu and you are up and running in 10 min or less! !!
We are still working on final pricing, but hope to have it retail for close to the same price as the Haltech Sport 2000 with Long-Harness kit. The Jumper Harness will also be available separately, and we are hoping to develop one for the 7M engine as well. The harness will feature a 6-pin break-out plug featuring 5 volts, sensor ground, two AV inputs and two digital outputs. There will also be an option for a plug-in WBO2 and BIC 1zz ignition coil harness.
We are always open to product ideas so if you need a a different configuration for a Jumper Harness or a different ECU, please let us know. There is many P&P harnesses available from SR20, EVO ,350Z, R35 GTR and more...
Haltech's new Platinum Sport line of ECUs have been released for over a year and have quickly become one of the most popular stand-alone ECUs on the market. Some of the world's fastest import cars and best tuners and builders now use the new Haltechs. The Sport ECUs are packed with features, are reasonably priced, and by far have the best software on the market. Some of the key features include:
- true sequential injection (up to 12 cyl on PS 2000 ECU)
- true sequential ignition (up to 6 cyl on PS 2000 ECU)
- On board 2.5 BAR MAP sensor (or use with external MAP up to 10 BAR)
- Wide band "Auto tuning" using user definable target AFR table
- VE tuning
- open-loop or closed-loop boost control
- boost by gear
- wide band O2 control
- closed-loop idle control
- two-step rev limiter, soft/ hard cut
- antilag, flat shift
- fan control
- data logging
- much, much more.
The Haltech Sport 2000 is the preferred ECU for all BIC Performance project cars:
With 14 channels capable of controlling injection and ignition duties, the Platinum Sport 2000 can support most modern engines (including 3 rotor engines) with multi-coil or conventional distributor ignition systems as well as aftermarket CODI systems.
It is capable of controlling sequential injection on 4,6,8,10 & 12 cylinder engines and direct fire ignition for engines up to 6 cylinders, or wasted spark ignition on engines up to 12 cylinders.
Visit www.haltech.com/index.php?option=com_content&view=article&id=105&Itemid=20 for a full list of features.
Haltech Sport 1000 EMS:
With 8 channels capable of controlling injection and ignition duties, the Platinum Sport 1000 can support most modern engines (including 2 rotor engines) with multi-coil or conventional distributor ignition systems as well as aftermarket CDI systems.
It is capable of controlling sequential injection on engines up to 4 cylinders, or semi-sequential up to 8 cylinders, combined with direct fire ignition for engines up to 4 cylinders or wasted spark ignition on engines up to 8 cylinders.
Visit http://www.haltech.com/index.php?option=com_content&view=article&id=94&Itemid=77 for a full list of details.
And the brand new entry level EMS, Haltech Sprint 500 features:
-4 x Fuel Injector outputs (for high impedance injectors only (ie: above 8Ω
-4 x Ignition outputs
For a Retail price of UNDER $1000
Visit http://www.haltech.com/index.php?option=com_content&view=article&id=120&Itemid=88 for a full list of details.
Randy@BIC
- VE tuning
- boost by gear
- fan control
- data logging
- much, much more.
Randy@BIC
