ok guys i checked my ecu grounds and i guess they were bad, because after fixing the ground connections code 11 went away. so after the code went away i changed my afm's and one out of the three i had seemed to make the car run ok, but after awhile the car started idling funny again. so i checked my codes adn came up with codes 24, 31 (which are both codes for afm) code 51 (switch signal) and code 52 (knock sensor, this is because i only have one knock sensor on the ge block and am using the gte cpu) so where do i start now. should i get a different afm, but everytime i buy a afm, it never seems to be a working one, i should know because tahts where my spare ones came from. so jetjock or cuel if u could please lead me in the right direction i will greatly appreciate.
