hey guys,
first off, the ass who did my harness cut off the friggin tps plug completely, i guess he mistook it for the trc plug. and he cut it so far back i had to take the harness back off the engine just so i can join the wires.
i had a spare harness that i took the plug off from, but apparently after not checkin up on it almost a month later, the plug disappears. so im a lil stuck right now.
but my idea was to just use that same plug for the trc sensor sense its identical to the plug for the tps sensor. but the only problem is i dont know which wires to match.
all i need to know is where all 4 tps wires go on the plug in order from left to right.
i have a jzx90 harness and if i remember, the tps wire colors are brown/white&red/blue&yellow/black&yellow, on the the soarer harness i had, the tps wire colors are different so im a lil confused.
hopefully i can get some answers by later tonite, cuz tomorow i wanna put the harness back on my motor as well as change my rear seal, put on my flywheel, clutch & tranny.
daniel
daniel
