cjsupra90;1125432 said:Although some might think this is a dumb question and no one asked it, but which bolts did you use? The manual flywheel ones, and not the one that were in your motor as an auto correct?
chris1039;1125510 said:i used the manual trans bolts. i did notice that the car they were on that they were really tight and we had to use a breaker bar to get them off.
Poodles;1125410 said:Older fasteners if in good shape have already been heat cycled and burnished giving better torque readings, no reason to replace unless they're torque to yield fasteners or you're upgrading.
adampecush;1125595 said:if the bolt is properly preloaded (and the thread form is intact), it will not back out. If ARP recommends moly lube with a specific torque value, listen to them, they've done their research.
loctite does not have the same lubricating characteristics as moly lube, so the torque required to achieve the same preload will be different.
upgradedsupra;1125830 said:Reusing flywheel bolts is like reusing a condom, you just don't do it.
