Motor swap question!
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
Hi guys, i know i had asked this question before. But there are no clear answers that came up for me.
My only question is that when i do my swap does it matter wich tranny and which harness goes together. Can a 5 speed harness work with an automatic??????? From this link http://www.supramania.com/forums/showthread.php?t=34560 and if the informations posted are right then i should have no problem doing the swap.
"Engine Wiring Harness- must be from same year as your vehicle (either '87-'88, '89 or '90+) drivetrain doesn't matter ($150 from The Parts Trader, a junk yard or ebay) "
^^^ This is pulled from that same page i had posted. If that is right then i can use my NA auto tran with my turbo 5 speed harness right?? no problem or do i have to find an auto turbo harness??? I had searched and also find information such that i cant do that, i will have to buy the auto turbo harness to use with my auto tran. Also, ECU's??? Does it matter, from what i read i can use a 5 spd ECU with a auto harness.....it is getting confusing
This here is what i found on the swap:
http://www.supramania.com/forums/showthread.php?t=27564&highlight=speed+auto
again...
http://www.supramania.com/forums/showthread.php?t=30027&highlight=speed+auto
anyways, a light shine on this would help me really much
8,873
The automatic car needs a TPS signal. They are not the same. Unless the 5 speed harness has plugs, which is very possible.
Are you swapping a 5 speed for the A340E?
akito
Jul 31, 2006
1,568
Springfield/Va
No, my car is originally an auto. the harness from the motor that i had acquired which came from a 5speed supra
