just finished doing my 1J swap with some goodies and creature comforts just want to change to a higher output alternator plus my volt meter stays at 12v exactly
tlo86;1472279 said:maybe you need a better wire from alt to battery, and ground... those were my reasons for low voltmeter readings (would flux between 11v and 14)
JonoTurbo;1475117 said:Check your ALT fusible link & fuses. Also make sure the main power wire from the alternator is still connected up, since you have to extend it in the 1jz swap it might have disconnected somewhere.
JonoTurbo;1475439 said:The stud on the alternator connects up to the harness where the original 7m alternator connected over by the battery. If you haven't done it yet, you'll have to extend that wire across the engine bay to the other side to hook it up.
turboguy327;1476966 said:You can safely run a power cable from the alternator B+ to the battery B+ without hurting anything. It will actually help you rather than hurt you.
