pln;1060673 said:
Ok Thanx for your answers. I assume I should keep hittin "s" when the engine is running? I´m just starting to learn mapecu so some questions may seem stupid :icon_bigg . what basic fuel pressure (no vacum) can you recommend starting with...not planning to go higher then 1.2bar with a t04 and 550cc.
a_sesshoumaru: So the 850cc map works aswell. Did you find it easier to start with that map?
For the 850cc i started from the 550cc i had already tuned, i use a base pressure of 45psi, boost kicks in at 4000rpm, it is really easy to tune, just need the wideband, i had the 550cc map tuned for 1.2 bar only, every car is different but you could start from it, now i am boosting to 24psi with no problem, and having better fuel economy on highway. i will attach the 550cc map, maybe it helps you to start.
Ps. i tried to attach it but the format is invalid, Pm me with your mail, i will send the map
