nosechunks said:defiantly sounds like low idle oil pressure.
yep, try using thinner oil. more like a 5w-30 or even a 10w-30. that way you actually get some oil flow. bearing like flow, to get flow your gonna need thinner oil.
nosechunks said:Thinner oil would make it worse.
Im going to go ahead and make an educated guess or hypothasize on the situation.
You have too much oil clearance in the bearings and or gears in the oil pump and or the oil pressure gauge you have is inaccurate. when cold the oil is thicker, making the pressure increase as a result of higher resistance to flow therefore giving the bearings more support from higher pressure. when the engine warms up the oil temperature increases, the oil thins as a result of temperature increase in turn decreasing oil pressure due to less resistance to flow to the point where the support between bearings is insufficient subsequently causing the low rpm, Hot, knock.
it wont do it when cold because the oil is thicker and "filling" the clearance between bearings, and wont do it at above 900rpm because then the oil pump is spinning fast enough to move enough oil to "fill" in the clearance space between the bearings.
the coincidence between cold and low rpm makes me believe its a low oil pressure issue.
This is all assuming there isnt any blocked passages starving bearings of oil flow/pressure.
supramike7m said:gonna have to disagree, bearings need flow, not pressure. you guys need to understand this. bearings need flow nosechunks your thinking that thicker oil will "coushin" the bearings. thinner oil after 900 rpm will give the bearings the "flow" they need. to "fill" the clearance space between bearings they need "FLOW" more oil flow. how can you think it has low oil pressure issues? he has way way to high of pressure for a 7m.
IJ. said:
