Going about my swap everything going pretty solid. Engine head rebuilt, all back to together, new clutch and trans in and bolted up. I'm just going over wiring to make sure I have no big deals. I've noticed 2 wires cut on the 7mgte wiring harness, one goes to the 'c1' male connector as I've read. the 6th pin is cut out. I've looked at my car's female connector it does not have a 5th pin but has a 6th pin. (iirc) Pics below. Should I plug in as is? Should I soldier a new wire on the blue white stripe and reconnect? Or should I take my 7mge's c1 connector and replace the 7mgte's c1 connector and connect it?
Next wiring question... The 3rd sensor on the bottom of the thermo housing's connector is cut off. I'm reading that it's the sensor that tells the aux fans when to turn on? Should I worry about this and buy a new connector for it?
I guess it's kind of hard to see in the picture cause the blue tabe is covering it but it's just a bare wire behind it.
Also misc question here anyone have a decent diagram of how the oil lines run? I've found diagrams of vacuum and coolant hoses.
