Intake spacer scam!!!
joeytvr
112
Louisiana
Ok guys if i was to tell yall I have a 1/4" spacer to go between your upper and lower intake mad of aluminum that would give you 12HP and 15lbs of tq and change your power curve for $230 who would sighn up?
This company has sold over 200 to nissan customers. We put two cars on the dyno hundreds of miles from each other. One made 2hp and the other lost 2hp with no real tq difference. Within margin of era for a dyno i would say but far from 12hp.
heres the link enjoy and fill free to add your thoughts here or there.
who would have bought one and who would fill riped off?
http://www.myspecv.com/f/view_topic.php?id=157504&p=1
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Hondata has been making a spacer gasket for years for hondas. It goes between the head and IM(not between top and bottom IM sections) It does help keep the IM from getting so heat soaked but they have never claimed hp gains from it.
If people were really buying this expecting to get a lot more HP and TQ then they have problems.
EDIT: And those Nology wires have proved time and time again to be much WORSE than stock plug wires. My friend had a turbo integra and it kept breaking up in high rpm's. I told him to put some stock wires on it and they solved the problem.
joeytvr
112
Louisiana
yeah i am sure the honda gasket was not made of aluminum to stop heat.
and yeah i have seen guys pull coil on plugs off to add a plug wire?/ wtf
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i think jim wolf or another vq35 tuning company had a plenum spacer a little while back, seemed credible (like the ones ej8 was talking about)
8,873
No, I wouldn't buy one, because it won't add any horsepower. It will only make the manifold 1/4" longer. What is next, the tornado?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
the "heat barrier" gaskets make sense to me... excpet the one my friend bought for his 4g63 was HORRIBLE quality, i had to enlarge more than few holes for it to fit right. I wasnt happy when i went to bolt it on. and it was made by JMFab (which is suppose to be a "great" vendor)
And i dont see why a spacer would make you gain power... thats just being dumb. haha
8,873
It isn't a heat barrier, when it is made of the same thing it is seperating. A phenolic spacer would be different, but it still won't pick up 12 horsepower.
joeytvr
112
Louisiana
thats mfunny we actually dyno tested that one also a while back 11hp loss! big surprise....lol
I cannot understand how someone that thinks they actually have knowledge of how a engine works and makes power would expect this to help.
I told the guys that still say it works that i will sell them a 2" thick one that would make 50hp then.....lol
joeytvr
112
Louisiana
theres was pheonolic or however you spell it.... but still not a measurable amount like they claim
Ma70.Ent
1,871
NJ
How could changing any gaskets give more power? Explain please.
By more, I mean a noticeable amount.
Phelonic spacers worked back in the day on Carb motors as it helps prevent boiling the fuel.
You could make the same power for longer not more power....
Thye're prone ot failure if you backfire the motor.
Tire Shredder
569
Oshawa
aluminum would do nothing.
The idea of a a "phenolic" gasket is that it will insulate the intake manifold from the head. In theory, reducing intake air temperatures. Phenolic does not mean to insulate...Phenolic is a type of plastic, it's name is often used incorrectly.
I intend to make a gasket myself out of teflon. It has a high melting point, seals well, is easy to cut and has a higher specific heat capacity than even air. It should help. Check this out.
http://www.autospeed.com/cms/A_0401/article.html
Honda owners have been swearing by them. Also, this isn't a new thing...domestic hot rodders have been doing it forever.
aluminum is pointless...
gixxer750
2jzget comingsoon!
Mississippi
Increasing plenum volume does things to multiport too.... Can move the power around, and change the way boost hits. I'm not validating their claims at all.... I'm just saying, it could have some effect, although it could even be negative.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I see the physics of increasing the runner length, and shifting the powerband, but if anything, making it longer is going to shift your powerband lower, giving you LESS peak hp.
I think that there are WAY to many variables on most consumer engines to warrant a 1/4" increase in runner length having much of an effect on power. If anything, evening out A/F mixtures would have more of an effect.
I couldn't afford the name brand Tornado, so I ended up with the Dust Devil, and I can't really tell a huge horsepower gain..........:dunno:
8,873
Now you call the 1JZ a dust devil? :biglaugh:
