I am looking into building a chumpcar ($500 or less racecar).
What I'm wondering is everyone thoughts on this setup...
this is how you determine if the car is a $500 car
If i took an 88supra and put a 2jzge and run it off the 7m harness. I remove everything that isn't needed in it as a racecar (except tail lights and head lights as this is a 24hour race)
Finish building your ChumpCar and, when it's 100% complete, wheel the car out
in front of your home. Jack the car up and set the car on cinder-blocks, or a stack
of 2x4's, just so the car is off the ground. Take the wheels off of the car (they’re
exempt from the value); take off the brakes (also exempt); remove the seat &
harness (exempt); and, remove the roll cage (exempt). Put a "Make Offer" sign
on the car.
My question is do you think this would be a $500 car to them?
If not what do you think the value would be (anything up to $2000 is just a lap penalty and really I'm just looking to have fun.)
I'm not interested in running the 7m as I'm halfway through my swap and just wanna put the stock 2jzge in and run it.
on the car.
