mattsplat72;1358425 said:So if I am understanding this right.
You will supply.
1 Complete housings capable of using HID or halogen light that I purchase.
I will supply the mount-bezel that will be used to mount Hella 90mm modules. (I might supply headlight and motor arms that will make the headlight setup easier.)
2 The basic wiring set up minus balllast's and the like.
Users of this setup will be on their on with wiring
I need to have
1 Lights of my choice with assoc. wiring
This setup is intended for the Hella 90mm modules. If you want to use another type of headlight, then that's up to your discretion
2 Pivot controller to adjust height from in car unless I want to control from under hood.
The pivot controller is optional unless you want to modify the headlight arm and motor arm. I'll consider supplying arms so that the Pivot is not necessary.
And you also stated that the Covers surronding bezel might be carbon fiber? If I didnt want CF would there be an option for FG?
To be determined
Would there be any cutting/hacking of the car ( ala Honestabe's flushmounts)?
The only thing that will need to be hacked is the headlight assembly. Honestabes required hacking of the radiator support; which will not be involved here.
Would they be reversable?
You'd have to purchase a new headlight assembly
Can we have some clearer pictures of lights on your car and maybe some pics of the set up off of car?
What's on my car is an unfinished product. I don't want to release pictures of an unfinished product. My intent for this thread is to see if there is gonna be enough interest to see if this groupbuy will be feasible. What I mean by feasible is if there will be enough people that will be willing to spend hundreds of dollars on a headlight setup that will result in this:
