finally got greddy profec spec 2.........
spike all over the place.......... cant get constant boost
on my 90 turbo.......... pretty stock........ bad actuator??????????? how can i test that...............
with the profec offf im running stock boost fine............. no spike constant 6 7 psi
im about to give up
set @ 20 %
set gain 8 psi
warning 12 psi
L 7%
spike all over the place...........
even when i set the gain to 6 psi it hit 6 psi then hi rpm spike and hit fuel cut....
my lines to the actuator is about a foot and a 1/2 both ways to turbo and actuator............. is this too long??????? causing spikes????????????
also the port on the boost controller soleniod NC should i cap that off or is it a bleeder hole???
im about to give up
set @ 20 %
set gain 8 psi
warning 12 psi
L 7%
