Exploded Spec Stage 5 clutch, beware.
Krister
Holset lover
May 2, 2005
159
Finland, Europe
Two local board members installed Spec Stage 5 clutches in their 2JZ / R154 swaps. They had the same outcome, the clutch exploded on both cases and on both broke the bellhousing. Both had under 400 miles on their clutches. Here's some pics of the carnage:
Krister
Holset lover
May 2, 2005
159
Finland, Europe
gaboonviper85;1055832 said:
LOL....that sucks...
Till try not to be an ass....I recomend a multi-disk clutch next time..
Both will be upgrading to multi-disk clutches.
Still.. what a piece of shit clutch. I had no problem with my Spec Stage 3, but looks like the Stage 5 has some issues.
No, it's not just Spec...
This design is not meant to handle the amount of abuse people put it though, the straps are DEFINATELY the weak point in the design.
Add in non-sprung hubs on the disk, tons of power, and hard shifting, and somehting is bound to give.
gaboonviper85
3,236
Northeast Philly
it didnt hurt the splines on the transmission shaft did it?.....id test the shaft with a dial indicator to make sure it didnt get bent.....something like this i could see fucking up a transmission.
gaboonviper85
3,236
Northeast Philly
must be kicking themselves in the ass when the spec clutch is almost $1000 and the multi-disks are like $1200....then the spec blows up and does $300 in damage....
2jzmk3
Guest
i agree the rps and act have the same issues.
how much power are the cars making? 400 miles, what were you doing, they say 500 miles break in period to heating up and cooling down for the metal to cycle..
gaboonviper85
3,236
Northeast Philly
annoyingrob;1055914 said:
Whre are you finding 1JZ multi-disc clutches for $1200?
tried to edit that but the forum went down for awhile in the morning...gave up and forgot to fix it.....found multi-disks for $1600 ish on one of our vendors site don't know for what motor though.
gaboonviper85
3,236
Northeast Philly
break-in has nothing to do with temp cycleing the metal.....FYI
Even if they took it baby soft on the clutches for the 500 around town stop and go miles....the clutches would have still failed under there driveing style.....and by the looks of it there style is a whole lot of clutch dumping!
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
935motorsports;1056526 said:
I'd be asking SPEC for some help on this one.
Hi, I didn't follow break in procedure and in fact did the opposite and your clutch blew up. HALP
:sarcasm:
gaboonviper85
3,236
Northeast Philly
:sarcasm:
Kinda sucks that this result isn't from not breaking in the clutch...would have failed anyway....but spec will not cover this under warranty....sucks for them I guess.
gofastgeorge
944
Texas
Glad that I bought a Quarter Master twin plate........
I had talked to SPEC, but they didn't convince me.
And no, it is definately NOT a bolt-on.
I am having to get my billet steel flywheel machined to accept it.
