One day when I went to go start my car, I turn the key and it just turns over and over without spark. So I pull it into my shop and find its the CPS.
I got a used one from a Member here and put it on. It started right back up.
It idled rough and was misfiring. So I go to do the timing and its not going at a consistent rate. So I take it off again to make sure everything was TDC and make sure I'm putting the gear on the CPS in the right spot.
I try it again and same thing. The car is also running very rich.
Do I need to replace something else? Or did I still get the groove in the wrong spot?
