So first off I went to court, engine was running fine, 30 min drive.
Court was finished, drove back home, underway the engine just lost power, almost died, it kept running till I got home.
When I got home I noticed timing was off, put timing back.
Had to go to work and it it gotten even worse.
The next day I changed the sparkplugs, still the same, distributor checked out, new sparkplug wires, still shyt.
So now the following is as this, the engine when cold it runs fine, once it gets over 140F it starts running bad, won't idle it dies, loss of power as in it won't even drive, no engines codes showing up (weird).
Oil is good, coolant is good, timing is good, checked for any lose wire, vacume leak etc..
IDK what else to check, engine runs fine when cold, I can drive around like its normal, but when over 140F it dies.....
Any tips or what??
Any tips or what??
