EMS 6860 firing order help. Do I use 1,6,3,4,2,5 or 1,5,3,6,2,4
vangb2
minnesota
I give up. I've tryed that set up and the ISC will not open. I have used the butterfly screww to keep throttle open.
I thank you very much for you help.
figgie
Twin Cities, Minnesot-ah
vangb2;1424362 said:
Idle vacuum keeps on changing so I can't give you an accurate reading.
Stop right there.
If the car can not idle steadily by itself without the use of the IAC. You wil lnever ever get it to work. You need a good steady state idle with the IAC disconnected and closed. Once that is accomplished. Then you can insert the IAC into the equation.
